customized Plastic Welding Equipment
Plastic welding rod
Production description:
Qingdao huashida machinery Co., Ltd is professional manufacture plastic welding rods extrusion line, at the same time, we produce the PE/PP/PVC etc plastic welding rods. The diameter of the welding rods from 3mm to 5mm, and also customize kinds of welding rods with different size as customer's opinion.
Products feature:
Acid resistant, alkali, salt, anti-corrosion and nontoxic. It is used for plastic hand extruder to weld plastic sheets/plate, contains, plastic pipelines and make plastic tanks and pipe bents.
Technical parameters:
Tensile test report
Sample No.Testing areaMax. loadTensile strengthElongation at break
111.34190.1816.77498.12
211.34198.1517.47510.83
311.34199.2917.57350.54
Average value11.34195.8717.27453.16
Standard deviation
4.960.4489.10
Max. value11.34199.2917.57510.83
Min. value11.34190.1816.77350.54
Qingdao Huashida Machinery Co., Ltd is a professional plastic extrusion production line manufacture since 2003. The factory covers 34000 square meters. Our products such as HDPE pressure pipe for gas or water transmission, structural wall pipe extrusion line, corrugated pipe extrusion line . The products have been exported to Middle East, Russia, Africa. Turkey, Korea.
Our factory locates in Cheng yang Industrial area, Qingdao ,Shandong Province. we have been approved and got certificate ISO90001:2008 by SGS. All the customers are welcome to visit the factory.
If you need more information about this machine. just call us 0086-532-80999083, we can give you consulting service for this machine. or email to us
Our products mainly include
Single Screw Extruder & Twins Conical Extruder
Vacuum Calibrating pre-insulated pipe outside HDPE casing Extrusion line
20-630mm Single/multi layer HDPE Pipe Extrusion Line
200-3000mm HDPE Spiral Corrugated Pipe Extrusion Line
Fiberglass reinforced PP-R Pipe Co-extrusion line
Plastic Sheet/ Plate Single/multi layer Extrusion Line
PVC Fiber & Steel Wire Reinforced Hose Line
Hand Extruder / Electro-fusion Welder
Heat Shrinkable sleeves (Normal style & Fiber Reinforced style)
Electro-fusion Girth Welding joint closure & Electro-fusion welded belt
TEL: 0086-0532-80999083
Website: http://www.hsdextrusion.com/ http://www.qdhsd.com/ http://www.qdhuashida.com/
QINGDAO HUASHIDA MACHINERY CO., LTD.customized Plastic Welding Equipment
website:http://www.hsdextrusion.com/plastic-welding-tools/
