Spalicing Fitting suppliers
Mid-Span Joint for ACSR conductor
Splicing Sleeves for ACSR Conductor, Shielding Wire(Hydraulic Compression Butt Joint). The inner sleeve is hot-dip galvanized steel, the outer sleeve and lining sleeve are aluminum.
The parameter of Mid-Span Joint for ACSR conductor
Catalog No.Suitable ConductorFigDimensions (mm) Slip Strength ≥(kN)Weight (kg)
Dφ1LL1dφ2
JY-70/10LGJ-70/10126-310---22.30.34
JY-70/40LGJ-70/4013220.0420220188.855.40.56
JY-120/25LGJ-120/2523217.04401701414.071.00.84
JY-120/70LGJ-120/7023625.56002802211.594.02.33
JY-150/35LGJ-150/3523018.5470180168.262.00.76
JY-185/30LGJ-185/3023220.0480170167.761.10.84
JY-185/45LGJ-185/4523621.0520200189.176.21.24
JY-240/30LGJ-240/3023623.0520170167.971.81.04
JY-300/40LGJ-300/4024025.5640190168.790.01.70
JY-300/50LGJ-300/5024026.0660210189.6100.01.79
JY-400/35LGJ-400/3524528.5680180168.2100.01.96
JY-400/50LGJ-400/5024529.5730220209.9120.02.19
JY-400/65ACSRJ95MCM24829.57602502211.0128.02.86
JY-500/45LGJ-500/4525231.5760200189.1120.03.12
JY-630/55LGJ-630/5526036.58402662410.3156.24.86
JY-720/50LGJ-720/5026538.0860246249.7162.05.79
JYD-70/40LGJ-70/4013423.53351202213.855.40.67
JYD-95/55LGJ-95/5513426.03701102416.074.21.60
JYD-120/25LGJ-120/2513426.0330902011.271.10.56Spalicing Fitting suppliers
website:http://www.power-insulators.com/conductor-fittings/spalicing-fitting/
